X-LS Encore kit
0 Members and 1 Guest are viewing this topic. Read 642 times.
DDK66
X-LS Encore kit
« on: 12 Feb 2020, 05:16 pm »
I recently received my X-LS Encore kit with all upgrades and everything looks great! I also ordered the flat pack kit from Peter Rawlings.
Any tips or words of advice for building the kit, this is my first speaker kit.
All comments appreciated!
David
Re: X-LS Encore kit
« Reply #1 on: 12 Feb 2020, 05:27 pm »
Welcome David :thumb:
Wind Chaser
Re: X-LS Encore kit
« Reply #2 on: 12 Feb 2020, 05:58 pm »
Hi David,
I’ve never built a kit, but you chose well. Welcome to Audio Circle.  :D
Peter J
  • Hmmmm
Re: X-LS Encore kit
« Reply #3 on: 12 Feb 2020, 06:29 pm »
First of all, DDK, thanks and welcome to AC.
I'm probably jaded, but best advise I can give is take you time. Assemble dry to develop a game plan so when you start gluing up there's a clear path to the goal line. Run screws in and out of the crossover mount holes before assembly to ease installation later. And something I realized just recently is NoRez is easier to install if temp is a little higher. Temps in my shop are low 60's this time of year and after I installed NoRez I aimed a hair dryer in the box for a for a minute or two and applied pressure again. The adhesive is pressure sensitive and wants to be intimate with the MDF  :thumb:
Last bit of advise is ask questions if you're in doubt. Much good advice to be had here.
DDK66
Re: X-LS Encore kit
« Reply #4 on: 14 Feb 2020, 05:44 pm »
Thank you Peter for all the tips and advice!  I'm sure I will have more questions as I go, so I appreciate being a part of the AudioCircle.
DDK66
