Tweeters on the inside or outside?
0 Members and 1 Guest are viewing this topic. Read 888 times.
Doublej
« on: 10 Feb 2020, 06:06 pm »
Until I can get things rearranged in the room to make room to put a pair of monitor speakers on stands, I will be putting them on their sides next to each other on a shelf under the television. The AVR will be set to 2.0 mode. Should the tweeters be on the inside, outside, or it won't make much of a difference either way?
srb
Re: Tweeters on the inside or outside?
« Reply #1 on: 10 Feb 2020, 06:11 pm »
I would say on the outside to reduce cancellation effects and possibly provide a better stereo image.
