FS: Klipsch RC7 Center Channel
0 Members and 1 Guest are viewing this topic. Read 564 times.
zapper7
  • Its time to have fun, its fun to have time
« on: 10 Feb 2020, 04:03 pm »
I am selling my RC7 center channel that has been in my smoke/kid/pet free theater for the last 5 years I've owned it. Please look at the photo of the left 8" driver, last owner had an issue with the flange but it has worked no problem the entire 5 years I've had it. I actually forgot about it till I took the grill off for photos to sell. Moved to an all Revel front end hence the sale. Have box and original packaging materials. Great center, crystal clear and easy to drive.
$450 obo
Specs from Klipsch;
1.75" titanium dome compression driver is coupled to an 8" square Tractrix® Horn
Two 8" Cerametallic™ woofer cones
2.5-way crossover tapered-array technology
BANDWIDTH 45Hz-20kHz ± 3dB
SENSITIVITY 98dB @ 2.83 volts/1 meter
NOMINAL IMPEDANCE 8 ohms compatible
CROSSOVER FREQUENCY 500Hz and 1950Hz (Tapered Array)
POWER HANDLING 200 watts (800 watts peak)
ENCLOSURE TYPE Bass reflex via dual rear-firing ports
DRIVE COMPONENTS Tapered Array system using one 1.75''(4.4cm) magnetically shielded, titaniumdiaphragm compression driver with an 8''(20.3cm) square 90˚x 60˚ Tractrix horn andtwo 8'' (20.3cm) magnetically shielded,Cerametallic cone woofers
WEIGHT 44 lbs. (20kg)
HEIGHT 9.1" (23.1cm)
WIDTH 26" (66cm)
DEPTH 13.5"
zapper7
Re: FS: Klipsch RC7 Center Channel
« Reply #1 on: 21 Feb 2020, 04:09 pm »
SOLD
