What are the 52 different board modifications?
0 Members and 1 Guest are viewing this topic. Read 1324 times.
« on: 9 Feb 2020, 02:38 am »
Hi Klaus,
Always wondered what are the 52 different board modifications available for the Stratos stereo mentioned on the site. Its possible inform us? :thumb:
Gracias
klaus@odyssey
Re: What are the 52 different board modifications?
« Reply #1 on: 9 Feb 2020, 08:11 pm »
Keep in mind that I can make you 60 - 70 different amps,  completely customizing for every customers system and budget !!!!
However,  in short terms the SE option that you are referring to has:
- all Vishay Dale military spec resistors
- all silver micas
- Nichicon gold and Nichicon Muse caps
- Bridge upgrade
Hand in hand with this upgrade should always be the Groneberg TS Premium topline output cable upgrade as well.....
Makes a nice improvement, for sure....
« Reply #2 on: 9 Feb 2020, 08:24 pm »
Thanks Klaus, there is a Single Ended output stage?
