Playing with port plugs
0 Members and 1 Guest are viewing this topic. Read 740 times.
veloceleste
« on: 8 Feb 2020, 03:38 pm »
In my sonically difficult room I experience a lot of bass gain and have used bass traps to great advantage but still experience some bass boom. It happens with with any type of speaker and I have changed placement and room arrangement until I've exhausted every feasible layout. After experimenting with rolled up socks (which the Mini T can spit out) and realizing some benefit, I ordered port plugs for my Mini T's. When plugging both speakers the bass output was reduced a lot, almost too much for my taste. Experimenting with a test disc and spl meter, I found that the best results were achieved plugging only one speaker. Since bass frequencies are not directional there is no effect to imaging. The mid bass is cleaner which also seems to clean up the midrange also. An asymmetrical room required an assymetrical solution. The left speaker is plugged. The left side wall runs the length of he room. The right side wall is only about four feet long before opening into another part of the room.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Playing with port plugs
« Reply #1 on: 8 Feb 2020, 03:45 pm »
Hi
Here is the anechoic measurements of the Model T as you add Port Plugs.
Stu Pitt
« Reply #2 on: 8 Feb 2020, 10:31 pm »
Hi
Do you have a similar graph of the Mini T?
« Reply #3 on: 9 Feb 2020, 12:10 am »
Hi
No sorry I do not but it would be similar to the model T with all plugs in.
james
