Does the SP3 support Ethernet over HDMI?
0 Members and 1 Guest are viewing this topic. Read 798 times.
WillyP
« on: 6 Feb 2020, 01:19 am »
Hi,
Well, the title says it all. There are HDMI cables on the market that support Ethernet over HDMI. Is this an attractive option for the SP3 or doesn’t it make a difference and is a HDMI cable without Ethernet just as good?
Kind regards,
WillyP
Phil A
Re: Does the SP3 support Ethernet over HDMI?
« Reply #1 on: 6 Feb 2020, 04:51 am »
As long as it is HDMI 1.4 or above (which the website indicates it is) it should be able to carry ethernet - https://en.wikipedia.org/wiki/HDMI - "HDMI 1.4 was released on June 5, 2009, and first came to market after Q2 of 2009.[63][99][100] HDMI 1.4 added support for 4096 × 2160 at 24 Hz, 3840 × 2160 at 24, 25, and 30 Hz, and 1920 × 1080 at 120 Hz.[101](§6.3.2) It also added an HDMI Ethernet Channel "
WillyP
« Reply #2 on: 7 Feb 2020, 01:34 pm »
Thanks for the reply. My SP3 has an HDMI 2.00 board and so has my 4K TV, but with a high-speed HDMI - Ethernet cable there is no connection between the two devices. This is not a big issue for me. It means that there is no need for use of an HEC cable.
Kind regards,
WillyP
« Last Edit: 10 Feb 2020, 09:37 pm by WillyP »
WillyP
« Reply #3 on: 9 Feb 2020, 09:25 am »
James,
Can you help us out? Does the SP3 support Ethernet over HDMI?
Kind regards,
WillyP
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #4 on: 9 Feb 2020, 01:03 pm »
James,
Kind regards,
WillyP
Hi Willy
I do not know but email Mike and he can help.  [email protected]
