SOLD Scansonic MB2.5
0 Members and 1 Guest are viewing this topic. Read 965 times.
pepperinca
« on: 31 Jan 2020, 05:10 am »
Scansonic MB2.5 in Black - superb condition
Condition of my pair is near perfect (see pictures). With the original box and manual.
Asking $1500.
Loudspeakers from Denmark, created by Michael Børresen, designer of the renowned Raidho speakers.
The MB-2.5 is a slim floor-stander with two 4.5” carbon-coned drivers and a sealed ribbon tweeter. It's a 2.5-way speaker with the second woofer assisting in the power demanding bass region. The cabinet is heavy, braced and curved, with carbon reinforcements.
The speaker is crossed over at 3.5 kHz, and the second woofer assists up to 200 Hz.
The MB 2.5 has a solid foundation in the Nordic design tradition. It is simple, sleek, elegant and visually square when seen directly from the front, and curved and organic when seen from an angle. The rounded edges of the cabinet reduces diffraction and minimizes the sonic imprint on the frequency response. It does not matter if your home is modern or classic, the timeless design of the MB-2.5 will fit in any.
REVIEW: Alan Sircom, HiFi Plus April 2015, concluded: "...you won’t find anything close to doing what the MB‑2.5 do for the money. They have enough of the Raidho genetic code to sound like Raidho, but not enough to stop a prospective Raidho owner from changing their mind... That’s the big thing about the Scansonic MB‑2.5, there are those who’ve heard what Raidho do and love it, but hate the price. They simply cannot or will not make that kind of financial commitment on a pair of loudspeakers, no matter how good. Those people will see the Scansonic range as a golden opportunity. It brings them much of what the Raidho speakers offer in a more affordable, more approachable package. Very highly recommended!" Check out the entire review
The MB-series features the same good solid, two-way binding post. The feet are machined from aircraft quality aluminum and can be adjusted to level the speaker. For added rigidness, Scansonic added a carbon sheet to the top panel; this, paired with extensive internal bracing, makes the cabinet inert and silent.
Read what Michael Børresen himself has to say about his new creation: Having worked with Raidho speakers for more than 12 years, I found myself faced with a completely new challenge when I was asked to design a new range of high-performance speakers for the Scansonic brand.
From the start, I was very focused on building on all the experiences and strengths obtained from designing the Raidho speakers. At the same time, I also had to be aware of the long heritage and the Nordic design tradition of the Scansonic brand. This time, the task also came with a budget and a desire to create the very best possible within financial limits.
It was clear to me from the very beginning, that some core techniques from the Raidho speakers would be of importance: The speakers had to be designed around a ribbon tweeter that works with at super lightweight diaphragm that is sealed around the edges to allow for a seamless transition to the midrange region.
Furthermore, they needed to be designed and developed with a speaker driver with a ridged, pistonic-type membrane.
WEIGHT LOSS FOR RESOLUTION TRANSIENTS AND SUPERB LEADING EDGES The MB ribbon tweeter has a membrane with an extremely low mass. It is formed by a Kapton-aluminum sandwich that is only 20 um thick, and the resulting mass is app. 0.03 g., which is approximately 50 times less than any conventional textile, ceramic, beryllium or diamond dome. The lower mass translates directly into higher resolution and less material coloration.
WEAVED CARBON CONES FOR STIFFNESS AND LOW COMPRESSION For the MB-series, we have developed a ridged, dustcap free, carbon membrane. By carefully optimizing the shape and stiffness, we have succeeded in making a very quiet woofer that blends beautifully with the ribbon tweeter. The woofer has an overhung magnet system, with long linear stroke and excellent bass performance.
« Last Edit: 5 Feb 2020, 11:11 pm by pepperinca »
Brettio
Re: WITHDRAWN Scansonic MB2.5
« Reply #1 on: 1 Feb 2020, 02:39 am »
Marked sold @ $1,400 on another site.
