OB sub frame questions
0 Members and 1 Guest are viewing this topic. Read 1083 times.
JTF
« on: 29 Jan 2020, 11:20 pm »
Do the H or W frame designs play a role beyond structural stability? Can the dual sub kits be built as plain flat baffles with support in the back? Maybe in a U configuration with a flat front and support wings on the sides in the rear. This is purely an aesthetic and WAF consideration.
-Jon
emailtim
Re: OB sub frame questions
« Reply #1 on: 30 Jan 2020, 05:30 am »
- Yes, they extend the effective baffle width keeping the front wave from cancelling the back wave.
- See this for more information - https://www.hifizine.com/2012/12/subwoofer-origami/
- See the preceding URL.  The H-Frame has a figure-8 radiation pattern.  The U-Frame has a cardioid radiation pattern.
JTF
« Reply #2 on: 31 Jan 2020, 02:07 am »
Thanks for posting that link
Danny Richie
« Reply #3 on: 1 Feb 2020, 04:21 pm »
And by separating that front and back wave, with the H frame or W frame side wings, the lower range is extended as well.
You can do it with a U shape frame as well, but it puts a LOT of pressure in the rear chamber and needs a LOT more bracing, structural support, and resonance control.
