Ava ultra double 350 amp tube recommendations.
0 Members and 1 Guest are viewing this topic. Read 903 times.
Boozebottler
« on: 27 Jan 2020, 08:10 am »
The amp is currently running JJ ELECTRONIC New Matched Quad JJ 12AT7 / ECC81 Vacuum Tubes. Are these an appropriate set of tubes for this amplifier? If not, what tubes are recommended? Thanks in advance.
Re: Ava ultra double 350 amp tube recommendations.
« Reply #1 on: 27 Jan 2020, 02:09 pm »
Welcome  :thumb:
You may want post this question in the AVA Circle where you will get more attention.
https://www.audiocircle.com/index.php?board=48.0
ntjetsmoke
« Reply #2 on: 27 Jan 2020, 03:17 pm »
Welcome!
dB Cooper
« Reply #3 on: 27 Jan 2020, 04:55 pm »
Aren't those the tubes supplied with the amp? Are the tubes new, or are they 'getting up there'? By 'appropriate', do you mean 'will they work' or are you looking for something with a particular 'signature'? If so, you may be disappointed- Frank has often pointed out (putting words in his mouth somewhat, here) that, as a result of his design choices, his amps are less sensitive to tube rolling than many. All these considerations would come into play in answering your question helpfully.
FullRangeMan is probably right about where the thread should be.
Oh, and welcome to the circle!
« Reply #4 on: 27 Jan 2020, 06:07 pm »
Greetings & Welcome to AC B-bottler   :thumb:
Phil A
« Reply #5 on: 27 Jan 2020, 06:52 pm »
Welcome!
Boozebottler
« Reply #6 on: 27 Jan 2020, 08:58 pm »
Thanks for the replies. These tubes were recently installed in this unit prior to my purchase. My knowledge of what tubes works best in what unit is roughly zero. Would I be best served leaving as is or chasing the dragon?
avahifi
    • http://www.avahifi.com
« Reply #7 on: 27 Jan 2020, 09:04 pm »
The correct tube type for any AVA product should be shown on its back panel label.
In your case, the installed JJ 12AT7/ECC81 tubes are correct and are the same as what we install in new production units.
I don't understand your reference to a "new quad set" however.  The Ultra 350 only uses two tubes, one on each audio board.
Note that you can reach me directly with your questions or comments at:  [email protected]
I can send you an owners manual if you request it via email at this address.
Frank Van Alstine
« Reply #8 on: 27 Jan 2020, 10:08 pm »
Thanks Frank :thumb:
Boozebottler
« Reply #9 on: 27 Jan 2020, 11:12 pm »
Hello,
The new "matched quad set" was the information provided on the receipt. The tubes were purchased from viva tubes. Perhaps the information provided was incorrect? I will try to find the time to pop the lid off and investigate. Thanks everyone for the help
