Over in the "music and preference" thread, I mentioned that I find my 1801F's a bit forward, even with the 8/12.5 resistor option. Dave suggested adding more resistance behind the tweeter. I'd like to experiment with that, and this thread seems like a good place to ask some questions.
As far as I can tell from reading the Resistor Options section of Dave's web site, there are two ways to reduce the tweeter's level: increasing the value of the series resistor, or decreasing the value of the parallel resistor. Which way would be better for (1) quick experimentation and (2) final application?
Dave's page indicates that increasing the series resistor from 7 to 8 ohms drops the tweeter level by 1 dB (1 ohm increase = 1 dB drop), and that decreasing the parallel resistor from 15 to 12.5 ohms reduces the tweeter by 1 db (2.5 ohm drop = 1 dB drop). Are these relations somewhat linear, at least over some range? That is, if I add a 2 ohm series resistor, will the tweeter level drop by another 2 dB? Or, if I decrease the parallel resistor by 5 ohms, will the tweeter drop another 2 dB?
Would a quick-and-dirty method be to just connect the speaker cable (I'm single-wiring) to the + woofer post, then use resistors of different values to jumper to the + tweeter post? Once I find a value that works, would I be better off adding that much resistance in series, or deriving a parallel resistor value that produces the same level drop, and swapping out the parallel resistor?
Ron
