New Remote Control Information Posted
0 Members and 1 Guest are viewing this topic. Read 1747 times.
John Chapman
    • http://www.bentaudio.com
« on: 13 Feb 2005, 04:22 pm »
Hello!
Finally getting to some long overdue web page updates. First up was the remote control information. I have added 2 new drawings in the downloads page:
1- Finally I made a mechanical drawing showing the dimensions of the motor assembly for the dact remote motor section. This page also has the dimensions for the circuit board and remote eye location, etc....
2- I have done a new revision of the remote pcb. There is a new wiring drawing for this board and it is posted at the same part of the downloads section.
The new PC board has both relay signals and switch signals for source up / down and toggle relay buttons all on a 14 pin header. This way a ribbon cable can be used  from the remote pcb to the relay boards for source switching and to the front panel for switches and led's for relay status. Although the relay option on the board is not often used this new header will allow cleaner implementation when it is installed.
Many Thanks!
John
