MCH-K38 does not power on
0 Members and 1 Guest are viewing this topic. Read 1605 times.
alexreusch
« on: 22 Jan 2020, 08:40 pm »
My MCH-K38 does not power on anymore. I already changed the spare fuse, but it did not help. Any idea what could be the problem?
rustydoglim
    • www.nuprimeaudio.com
Re: MCH-K38 does not power on
« Reply #1 on: 23 Jan 2020, 11:32 am »
You should contact your distributor/dealer and/or create a help desk ticket from the website.
If you can do some basic diagnostic such as measuring DC voltage out of the power supply (you have to open the cover), that will help.
Otherwise, turn off all amp channels except one, and try to see if the power supply will work - this procedure is to test if a particular failed amp module could have caused the power supply to temporarily shut down.
Regardless, you should use the Help Desk for such issue.  Our support stuff don't read audiocircle.com, and we need to leave a trail of messages in the Help Desk ticket for staff to follow up.
