FS: Bel Canto DAC/Pre 3.7 & VBL1 (Power Supply)
0 Members and 1 Guest are viewing this topic. Read 1343 times.
who?me?
« on: 19 Jan 2020, 03:43 am »
For Sale is a high end Bel Canto DAC/Pre & external Power Supply, called the VBL1.
{I can also sell these pieces with the Bel Canto Renderer ("RefStream Asynchronous Ethernet Renderer") for $3200 total. The Renderer is $800 by itself. Using the Renderer with the DAC and VBL1( External Power Supply) is the optimal front end system.}
VBL = Virtual Battery Supply, b/c the noise level is so low due to BCs propriety power supply, proprietary filers, that they have been improving for over 20 years.
I am the second owner, have had her for about 2 years. This is the best DAC Ive ever used. Ive been using Bel Canto DACs for 8 years, continuing to move up the chain to higher and higher quality.
The SQ is excellent IMO. Bel Canto (a US company in Minneapolis) has been in business since the 1980s. They first specialized in tube audio gear, then took that knowledge, and developed Class D products over at least the last 2 decades. But BC still "voices" their products to reveal a tube-like quality, especially in the mids/vocals, but especially in the airy highs and low frequencies that still have slam and dynamics like SS.
This DAC 3.7 has a hybrid power supply. Please see the Bel Canto website link above. There is some very slight fraying on the umbilical cord (see last pics). Obviously, it does not affect SQ. But I disclose it for Full Disclosure.
-From the BC website:
"DAC 3.7 Control Preamp:
Independent chassis separate power from the focused DAC function, creating a pristine environment to process signal revealing incredible detail and audio resolution. You’ll hear deeper into the recording than ever before.
-Class Leading 126dB Dynamic Range
-24 Bit Volume Control
-5 Asynchronous Digital Inputs
-ST Fiber
-Analog Input
-Independent Power Supply"
More from the website:
"HDR Core is the result of 20+ years of engineering to refine the digital to analog process, and is comprised of 3 major components: Low Noise and Ultra Low Noise Master Clocks, Advanced Asynchronous Interfaces, and Dual Mode Low-Noise High Efficiency Power Supplies. HDR Core technology is fundamental to every e.One DAC and Integrated product, creating the most realistic, open, and defined musical experience possible."
"The VBL1 power system lowers the broad band noise floor, reduces AC power noise and improves the overall musicality of the DAC3.7. The VBL1 uses new linear regulator technology combined with a high isolation power transformer to deliver a focused, optimized single 12V output. This critical power stage allows the DAC3.7 to perform at its best with increased sonic resolution, low level dynamics, spatial information, harmonics and timbre."
DAC 3.7 Specifications
Digital Section:
Maximum Data Input Rate
24bit Data at 192KS/s: AES XLR, SPDIF BNC/RCA, ST Fiber, TOSLINK
Master Clock Jitter: 70 femtoseconds RMS, 100Hz-1MHz
Analog Input: 24/192 DAC Section:
Maximum Output: 5.5 Vrms balanced XLR, 2.5 Vrms RCA
Output Impedance: 200 ohms balanced XLR, 100 ohms RCA
Frequency Response: 20 Hz-20 KHz, +/- 0.25dB
THD+N: <0.0015%, 5.5Vrms balanced out, 1KHz
Output Noise: 3uVrms A-weighted 20Hz-20KHz
Dynamic Range: 126dB A-weighted 20Hz-20KHz
Analog 24/192 ADC Section:
Maximum Input: 2.5 Vrms RCA
Input Impedance: 12K ohms RCA
THD+N: 0.003%, 2.5Vrms in, 1KHz
Dynamic Range: 110dB, A-weighted 20Hz-20KHz
FYI: Im selling several pieces of equipment (3 systems) due to moving overseas.
Please see other ads.
Im selling an entire BC system:
the BC REFStream Renderer,
this DAC/Pre,
& a pair of REF600 Monoblocks (SOLD)
All black in color.
Shipping: 2 boxes, they have the same dimensions (dimensions above are correct) but the Weight of the 2 boxes is slightly different. One box is 14 lbs, the other is 13 lbs.
1. DAC/Pre
2. VBL1: Virtual Battery Line (external power supply)
THANK YOU!!
EMAIL WITH ANY QUESTIONS AND ANY OTHER GEAR YOU ARE LOOKING FOR.
REASONABLE OFFERS CONSIDERED
LOWBALLERS WILL BE CURSED
Includes:
Original BC inner and outer boxes, see pics. Original owners manual.
Original BC umbilical cord. 2 stock power cords.
