Dac-9h: adding Vu-meter to coax output ?
0 Members and 1 Guest are viewing this topic. Read 1457 times.
Florin
« on: 18 Jan 2020, 02:10 pm »
I really want to add a pair of vu-meters to my Dac-9h ( something diy ), and i was curios if it's safe to use the coaxial output while using the headphone jacks. (i'm only using headphones)
Or can it have any negative impact doing that ?  (from my test, it works to output to headphones and some active speakers over coaxial)
I was planing on using the TEK Active control module for stereo meters.
Florin
Re: Dac-9h: adding Vu-meter to coax output ?
« Reply #1 on: 30 Jan 2020, 08:27 am »
well ... did it anyway.
The only small problem is that the RCA output from the Nuprime is influenced by the volume knob, so the vu-meters level is modified, but it's not a big issue, as i usually listen to similar level.
An upgrade would be to put some external level control on my vu-meters.
The biggest challenge was to cut that 10mm aluminium face, luckily my wife managed to do it at work.
rustydoglim
    • www.nuprimeaudio.com
« Reply #2 on: 1 Feb 2020, 06:00 pm »
DAC-9H/9 headphone amp and line out (XLR or RCA) are designed to work in concurrently if necessary.
Nice when you have access to a machine shop  :thumb:
