0 Members and 1 Guest are viewing this topic. Read 5176 times.
I'm currently streaming from my MacBook Pro Laptop via hardwire to my Anthem MRX510 Receiver.
Not sure exactly what "hardwire" means. Are you using(a) an analog cable from the MacBook combo headphone jack into RCA analog inputs on the receiver (thereby utilizing the MacBook's internal DAC)or(b) an optical Mini Toslink cable from the MacBook combo headphone jack into an optical input on the receiver (thereby using the receiver's internal DAC)?
You could see if your model MacBook Pro has an optical digital connection hidden in the headphone jack. I’m using my MacBook this way and I bypass the laptop DAC and send the optical input to my receiver and use the receiver DAC (or you could use external DAC). Check laptop specs for outputs and see if it has optical. You use a Toslink cable with a special mini jack (3.5mm?) adaptor. See pic. You can adjust the output in Applications/Utilities/Audio MIDI Setup.app
..... (Good sound being subjective)Cheers!
.....Sum: buy some combination of a preamp, DAC and streamer, and any streaming service and very likely you’ll use streaming services 99% of the time and love it......
..... So differences in DACs or various formats are minor compared to the quality of speakers, recordings, rooms, even amps.....
The new macbook pro do not have an option to stream via toslink link I learned that when I purchased a 13 " this year for my college going kid He decided to use my old 2011 MBP and I got stuck with the new MBP , I do have a Chord Mojo-DAC/Hp/pre/ but that option would cost you another 350 used to 550new you can try connecting it via USB-C Digital Multiport adapter $ 69.99 from Apple and see if that would do the trick Asghar
I've moved on from the MBP but did connect it via USB-C - HDMI and it looked like it gave me more options for resolution but I'm not convinced they are real. I tried different settings and they all sounded the same.
