0 Members and 1 Guest are viewing this topic. Read 4270 times.
I'm setting up a room as a semi-dedicated audio listening room. Currently I'm planning on doing some basic treatment:- Absorbers at first reflection points (side walls, front and back walls, cloud on the ceiling)- Bass traps in the front cornersIs this the sort of treatment plan for which taking room measurements as I put treatment in would be advisable? Or is it basic / no-brainer enough that I could just proceed and trust my ears?
Bass control - yes.Cloud - maybe. Depends on what problems are there, what the room height is, the type of speaker, etc.Side wall absorbers - maybe. If you have SBIR issues, then yes. If not, then diffusion could be a better option.Don't forget the wall behind you pending the distance you are from it, where you sit in relation to the length, etc. Many nasty nulls (or general buildup if you are sitting close) can come from this area that is often ignored.
JLM,Those Dutch & Dutch 8c speakers look VERY interesting!
The room is quite square? I know some who find they get better sound in square rooms by setting up the audio system on the diagonal. Of course, that's not always practical, depending on how else the room is used.
Yes, somewhat square. Approximately 12’ x 12’8” x 7’ (3.7m x 3.9m x 2.1m). I’ve heard about setting the room up on the diagonal. Unfortunately, do to the other usage of the room, that’s not really a practical setup. So far, untreated, I’m pretty happy with the tone of the system.... but soundstage leaves a bit to be desired. It sound like there are three distinct stages... center left right... rather than one cohesive stage.
What speakers are you running, and where is your listening position relative to the side walls and wall behind the listening position?
Have tried the diagonal setup in rectangular rooms, helped to reduce first reflections as "side" wall reflections barely exist, but bass behaves as waves, so orientation doesn't affect bass performance. Such a small square room leaves few options. Can you pick a different room? Or line two adjoining sides with absorption? Again suggest reading Toole. Using ears alone can be very misleading as we acclimate so easily. The question boils down to what you're striving for: high-fidelity or a pleasing/entertaining experience. Audio is a individual pursuit, so each must decide for oneself what direction to follow. But note that high-fidelity has a single answer, while personal tastes have no standard.
