Very nice looking ultrasonic cleaner from China
0 Members and 1 Guest are viewing this topic. Read 1066 times.
simoon
« on: 7 Jan 2020, 09:05 pm »
So far, all the ultrasonic record cleaners coming from China have been some pretty DIY looking products, using the same 6.5 liter tank that is all over Ebay for $100.
This one, from respected manufacturer of industrial ultrasonic cleaners, Codyson, is a bit of a nice change.
And only about $400, including shipping.
Quick YouTube video.
https://www.youtube.com/watch?v=IF9k5ADPXUY
BobRex
Re: Very nice looking ultrasonic cleaner from China
« Reply #1 on: 7 Jan 2020, 09:35 pm »
Looks like an OEM Kirmuss.
wushuliu
« Reply #2 on: 7 Jan 2020, 09:48 pm »
I'm gearing up to get back into the vinyl game so I'm curious to know more about these cheap ultrasonic cleaners.
S Clark
« Reply #3 on: 7 Jan 2020, 10:22 pm »
The primary thing to know is that they work- really well.  There is as much difference between an ultrasonic cleaner and a vacuum cleaner as there is between a vacuum rig and a Disc Washer brush.
simoon
« Reply #4 on: 7 Jan 2020, 11:23 pm »
Most reports are, cheap ultrasonic cleaners work just as well as the expensive ones, or at least very close.
Most of the cheap ones use the same ultrasonic tank, a 6 liter tank found all over ebay for about $100.
Then there is some motor/record holder device that is used along with the tank shown above.
Something like the Vinyl Stack.
Or CleanerVinyl.
Either way, they are much better than vacuum record cleaners.
