0 Members and 1 Guest are viewing this topic. Read 2391 times.
If it's a problem disable the volume control.
This is realy a problem my pre-amp has to be set 10 positions higher then normal.
You need to disclose the pre-amp name and model number.
?? What has my pre-amp to do with this problem?
Hi HoimanI checked my BDP-3 and the max volume the slider shows is 3/4. I will ask Chris to have a look - thanks for catching that.james
Does that mean it’s cutting off bits of data? Doesn’t full output give the full digital stream?
If you put it from None to software it gets its full range back.
This makes sense. Maybe the digital volume control was not meant to be a real "gain" or volume control but just as an accommodation in case you needed it.
Till this update you could move it to far right. Do you have a BDP-3 then you should know.This is also why I didn't understand your question about my pre-amp. There is still a dac between the BDP-3 and my pre-amp (a Esoteric C03xs), the DAC is a Bryston BDA-3.
Which update are you referring to? I still have the 2.42 update.
