Need help: Connecting BDP-2 to Roon Core
0 Members and 1 Guest are viewing this topic. Read 1015 times.
TJ-Sully
« on: 24 Dec 2019, 03:34 pm »
Hi all (and Chris!),
Hoping for some help :)
I am having challenges connecting my BDP-2 to Roon.
I have a BDP-1 as well - and it connects to Roon flawlessly.
I bought a used BDP2 recently, and after clearing the previous users IP information, and updating the firmware - still no connectivity to Roon.
The MPD software works great. External HD and internet radio stations work perfectly.
somehow....I suspect there must be a IP address issue or some other simple fix related to the Router...?
I rebooted the BDP2 many times, and rebooted my Roon Core server.  still no go.
I will try unplugging / replugging in the router itself and see if that helps.... :scratch:
TJ
pdkm
Re: Need help: Connecting BDP-2 to Roon Core
« Reply #1 on: 24 Dec 2019, 04:30 pm »
This is probably not helpful, but maybe the bdp-2 needs to be enabled first? ROon > settings > audio
If the core is on a computer you can access maybe try pinging the bdp-2 to see if it can communicate at all - there's that handy http://mybryston.com/ to get the IP of bryston devices on the network, though, i assume you already have the IP since you are using it to play radio stations through the web interface. Is there anything different about the way the bdp-2 and bdp-1 are connecting to the network? Maybe one is wireless and maybe you are segregating traffic between the two networks?
TJ-Sully
« Reply #2 on: 25 Dec 2019, 05:39 am »
hi pdkm, thanks for trying to help.  still not connecting...
TJ
Grit
  • - Garrett
« Reply #3 on: 25 Dec 2019, 08:43 am »
Try a dedicated IP address. Easiest way is to have your router assign the same IP address every time.
TJ-Sully
« Reply #4 on: 26 Dec 2019, 01:22 pm »
Thanks Grit. I will try this approach when I get back home tomorrow...cheers! TJ
TJ-Sully
« Reply #5 on: 3 Jan 2020, 06:55 pm »
still haven't figured this out......waiting for Chris to return from holidays to help... :)
TJ-Sully
« Reply #6 on: 3 Jan 2020, 07:49 pm »
all good. thanks Gary Dayton!  :thumb:
