0 Members and 1 Guest are viewing this topic. Read 7169 times.
Realistically I'm not able to get more than about a foot between speakers and back wall.
My question is whether certain speaker technology is better in a room that has lots of reflections? For example, a waveguide tweeter provides a wider soundstage but would it be more difficult to dampen in a room like this? I'm assuming a hard dome tweeter would, in general, appear 'brighter' than soft dome or ribbon - is this effect amplified in a room with lots of glass or tile? Are there similar things I should consider regarding the midrange?
I know the room has a tremendous amount to do with audio quality and I'm trying to figure out at what speaker price point I stop seeing improvements due to limitations of the environment.
Am I wrong to immediately think of Ohm speakers? Surprised they haven't been mentioned yet.
Ohm speakers are omni-directional, the exact opposite of Controlled Directivity, and are intended to interact with the room. The Ohm website is misleading. This is exactly the opposite of what the Original Poster is correctly after.Room correction software, should be considered as the final tweaking step after getting the right room (size, shape, materials) first; synergistic speakers to the given room second; and appropriate treatments - contact GIK here at Audio Circle (third). Software correction of mid/high frequencies will change the character of the chosen speakers, so most recommend limiting it to bass frequencies (below 200 Hz).In this case the room size and shape are good, but too many hard surfaces and the described speaker placement is less than ideal. GIK absorption panels can be customized to complement nearly any aesthetic. Area rug is a good idea. Mid/near-field listening would help reduce room effects but don't know if a 4-10 ft equilateral triangle listening setup is feasible. Headphones are always an option. The Amphion monitors I mentioned fit in your price range, but hard to find a dealer for an audition.
JLM, it sounds like the Ohm Acoustics speakers aren't totally omnidirectional, due to the presence of padding, at least from what I've read here: https://www.stereophile.com/floorloudspeakers/687ohm/index.htmlTechnically, however, a totally omnidirectional speaker has constant directivity.
