BDP2 and PS Audio Direct Stream DAC
0 Members and 1 Guest are viewing this topic. Read 1329 times.
TJ-Sully
« on: 19 Dec 2019, 02:18 am »
hi all
I am about to receive a BDP-2 in the next few days....an upgrade from my steady performing BDP1.
I am using a Direct Stream DAC, and wondering whether anyone using these 2 products have noted any issues playing higher resolution files (192/24).
I recently read on the PS Audio forum that some folks have noted distortion in the above scenario.
maybe this a question for Chris...should I expect some compatibility issues?
thanks for your help.
TJ
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDP2 and PS Audio Direct Stream DAC
« Reply #1 on: 19 Dec 2019, 12:23 pm »
hi all
TJ
Hi TJ
I am not sure on this but I think the PS unit up-samples all inputs to DSD ( you do not hear the native resolution) and that may cause some issues.
Chris may know better as we did have a sample of the PS unit a while back for testing.
james
TJ-Sully
« Reply #2 on: 20 Dec 2019, 12:55 am »
hi James
thanks for responding.
yes, that's right - the PS Audio Direct Stream DAC converts the incoming signal to DSD then applies a filter.
look forward to hearing Chris' observations...and whether there is in fact a distortion observed playing high resolution PCM files.
I am hoping it's all good!
cheers, TJ
unincognito
    • bryston.com
« Reply #3 on: 22 Dec 2019, 05:22 pm »
hi all
TJ
If the BDP-2 your receiving has the same audio card as your BDP-1 then you shouldn't need to worry.  If the BDP-2 has the new IAD card then there could be a problem with the ps audio DAC picking up the audio signal at higher sample rates (176/192).  I heard from another customer a few weeks ago that ps audio might be releasing an update at some point to improve locking on to signals.
Chris
TJ-Sully
« Reply #4 on: 24 Dec 2019, 04:06 pm »
thanks Chris.  yep, my BDP2 has the IAD card. will let you know how things go..cheers!
Socal77
« Reply #5 on: 16 Feb 2020, 06:16 pm »
Hello all,
I just noticed this thread as well as the long (and interesting :o) one on the PS Audio forum regarding the issue with the BDP-2 IAD and 192/24 files to the PS Audio DirectStream DAC.
Is this a known issue for the BDP-3 also?  Thanks!
