0 Members and 1 Guest are viewing this topic. Read 2960 times.
Hello, I recently acquired a pair of Usher BE718 with DMD tweeter. I’m wondering if it is worth pursuing the GR crossover modifications? I can’t find much info about what exactly is changed aside from the different brands of components and that vertical dispersion was improved. The speakers are great, though I feel there is a slight hardness to the sound and that they may sound better with the crossover that all the review units were using. What do you guys think?
The Usher Be-718 was both less sensitive than average and less sensitive than specified, at an estimated 85dB(B)/2.83V/m.Offsetting the speaker's need for voltage, however, is an impedance modulus that remains above 6 ohms throughout the bass and midrange, and drops below 6 ohms only briefly in the treble (fig.1). Only a combination of 5.7 ohms magnitude and –41° electrical phase angle at 2.5kHz keeps the Usher from being rated an easy load for the partnering amplifier to drive.
The Be-718's drivers, crossovers, and timed-aligned cabinets are designed and built by Mr. Tsai Lien Shui at Usher Taiwan, with finishing cosmetics supplied by Kam Young in the United Kingdom. Dr. Joseph D'Appolito, Usher's long-serving technical consultant, provides crossover tuning here in the 'States. Crossover parts and JPS Labs internal wiring are made in the USA, while design wizard Danny Richie, of Texas based GR-Research, adds the finishing touches by selecting the crossovers premium parts, improving the speaker's baffle step compensation and vertical off axis response.
Thanks for the info, so the upgrade was designed only for the Titanium Beryllium tweeter?I’m guessing Usher changed the stock crossover when they changed to the DMD.
