**SOLD** VIENNA ACOUSTICS BACH GRAND speakers - Beautiful Cherry Finish
0 Members and 1 Guest are viewing this topic. Read 767 times.
pepperinca
** SOLD ** Excellent European sound, and absolutely beautiful (furniture grade) cabinets.
Includes: Speakers (pair), spikes (8), spike discs (8)
SoCal pickup is preferred as I do not have the boxes.
MSRP: $1995   -   Sell for $700
Other Notes: "The aspect of Bach’s mathematically precise compositions that demanded astoundingly inventive solutions to musical problems is fully evident in the Vienna Acoustics speaker that bears his name. Of note, the beautiful floor-standing cabinet features Twin Balanced Reflex (TBR) loading of the potent 7” X3P mid-bass driver. TBR combines a conventional rear port with a groundbreaking airflow control port on the front of the cabinet allowing for class-leading bass output and control. Further, the complex front port system provides an extraordinarily compact driver configuration by positioning the refined 1” triple stacked silk dome tweeter directly in front of the port, contributing to a sonic presentation of power and verve that belies the speakers’ compact proportions."
Specifications:
Tweeter: Hand-coated 1" Silk Dome
Mid-Woofer: 7" X3P Transparent Cone
Bass System: Double Bass Reflex
Bass Function: Impulse Optimizing QB 3 (Quasi Butterworth)
Crossover Components: MKP Capacitors, 1% tolerance
Air Coils, 0.7% tolerance
Metal Film Resistors, 1% tolerance
inductance free
Crossover Function: 2-way 6dB and 12dB Bessel
Impedance: 4 ohms
Frequency Response: 35Hz - 20kHz
Sensitivity: 90dB
Recommended Amplifier Power: 30 - 200 watts
Weight: 80 lbs. per pair
Dimensions (W x H x D): 7.4 x 34.6 x 9.8 inches (without spikes), 188 x 878 x 250 mm (without spikes)
Base: Threaded spikes
« Last Edit: 14 Jan 2020, 06:30 am by pepperinca »
