omnia WR1
0 Members and 1 Guest are viewing this topic. Read 2311 times.
giordy60
omnia WR1
« on: 6 Dec 2019, 01:22 pm »
Jason a question:
with the nuprime app (ominia receiver) I can't get the files residing in the nas that is in the same network to be read, the things is possible use the Mconnect app ..... why ?
thanks !
« Last Edit: 7 Dec 2019, 01:28 pm by giordy60 »
rustydoglim
Re: omnia WR1
« Reply #1 on: 14 Dec 2019, 09:47 am »
Do you still have this problem?  Please update to the latest Omnia Receiver app (for iOS device, you have to follow the instruction on the product page Download tab, until it is available on Apple App store).
Please describe your NAS and what type of files are on it.
rustydoglim
Re: omnia WR1
« Reply #2 on: 14 Dec 2019, 10:02 am »
Note that Omnia WR-1 can be connected directly to the "Digital Port" of IDA-8 and DAC-9, without the need for separate power supply.
mresseguie
Re: omnia WR1
« Reply #3 on: 23 Dec 2019, 02:20 am »
Jason,
I have a non-Nuprime DAC <sorry>. I assume I can add a WR-1 to my system by connecting the WR-1 to my DAC with a coax cable (my DAC has a coax input). Once connected, I can then stream <via Airplay> TIDAL from my MacBook Pro/iPhone/iPad. Additionally, I can connect my iPhone/iPad to the WR-1 using a 3.5mm to 2 male RCA adapter cable, correct?
Michael
rustydoglim
Re: omnia WR1
« Reply #4 on: 25 Dec 2019, 06:13 pm »
Yes
