Industry Circles
Bryston Limited
Is there any documentation on how to use the Backup function under Applications?
0 Members and 1 Guest are viewing this topic. Read 717 times.
Pundamilia
5 Dec 2019, 11:23 pm »
I've noticed that there is a Backup capability under the Applications button in the Dashboard. I'm not sure of it's purpose or how to use it? Is it meant to backup one's library to CD/DVDs or is it for ripping a Backup from a CD/DVD to one's library?
unincognito
Industry Participant
ยป
Re: Is there any documentation on how to use the Backup function under Applications?
6 Dec 2019, 04:09 pm »
We have the BOT manual
http://support.bryston.com/downloads/BDP/BOT-1/documents/BOT-1%20Owner's%20Manual.pdf
The feature doesn't rely on having a BOT just a USB optical drive, a usb dvd reader or burner works best
Chris
Pundamilia
Reply #2 on:
7 Dec 2019, 04:43 am »
Thanks, Chris,
That looks like exactly what I was asking for. I'll have to give it a try.
Industry Circles
Bryston Limited
