Industry Circles
Odyssey Audio
klaus@odyssey
The Gain for the Mono Extreme
0 Members and 1 Guest are viewing this topic. Read 2126 times.
lovelexicon
30 Nov 2019, 09:45 pm »
Hi:
Does anyone know what is the gain for the Mono Extreme. My version is from 2003.
klaus@odyssey
Facilitator
Re: The Gain for the Mono Extreme
1 Dec 2019, 05:43 am »
2003 ???? Should be between 30 - 32 dB
geerock
Reply #2 on:
1 Dec 2019, 02:18 pm »
While on some numbers....
Can you give me the input impedance for your all in Kismet in Stratos monos?
Need to match up a pre. You built them for me a couple years ago. I've been emailing you.
JackD
Reply #3 on:
2 Dec 2019, 06:47 pm »
Should be 22k like the rest of the amps. Case is just cosmetic.
lovelexicon
Reply #4 on:
3 Dec 2019, 03:02 am »
Klaus:
Thank you for the answer!
Industry Circles
Odyssey Audio
klaus@odyssey
