Replacing spades on Groneberg speaker cables...
0 Members and 1 Guest are viewing this topic. Read 1224 times.
avalon65
« on: 9 Feb 2005, 01:45 am »
I'm not sure why Klaus sells the Groneberg speaker cables with the 6mm spades because I can't get them to fully fit on my Stratos binding posts. I think the guy I bought them from had the same problem because they are chewed-up and bent pretty good. Does anyone else have this issue? I've resolved to buying larger aftermarket spades, but looking for advice on whose I should buy and where to get them for a reasonable price. I've already been to Parts Express and the only sizes that work are Monster and WBT. I'd prefer not to buy the Monster and WBT is too pricey. Any suggestions???
jcoat007
« Reply #1 on: 9 Feb 2005, 03:15 am »
You can also turn the speaker terminals 90 degress and the spades will fit fine.
On my stratos monos I did that and it worked great.
Just loosen them from inside the case, turn it and then re-tighten.
