hello from iowa !!!!!!!!!!
0 Members and 1 Guest are viewing this topic. Read 1237 times.
Norman bates
« on: 26 Nov 2019, 12:26 am »
also norman bates over on diyaudio.
currently using a morel solstice kit from partsexpress.
Soon to have a w8-2145 in a big sealed under tv (acting as a center channel).
Using a Nakamichi ta-2a to drive it (current favorite).
Re: hello from iowa !!!!!!!!!!
« Reply #1 on: 26 Nov 2019, 12:58 am »
Welcome Norman :thumb:
Phil A
« Reply #2 on: 26 Nov 2019, 01:29 am »
Welcome!
Mudjock
    • Sehlin Sound Solutions
« Reply #3 on: 26 Nov 2019, 02:43 am »
Hi Norman,
I'm located in Bettendorf.  I spend most of my audio-related time designing speakers, but am interested in the rest too.
I've spent time with the designer of the Solstace kit at diy events over the years - great guy - very talented and knowledgeable.
The Nakamichi TA series is quite good - I had a TA-3A for a while.  I think the power section is a little better than the pre, but it's definitely one of the top receivers from the 1980's.  The only one I am sure I liked better was the Luxman R-117.
Welcome aboard!  I'm not sure exactly where you are located, but I can at least help connect you with speaker nerds close to you if you need that...
Wind Chaser
« Reply #4 on: 26 Nov 2019, 07:55 am »
Welcome to AC!  :thumb:
« Reply #5 on: 26 Nov 2019, 03:56 pm »
Greetings & Welcome to AC Norman   :thumb:
Norman bates
« Reply #6 on: 27 Nov 2019, 12:29 am »
thank you everyone !!!!!!!!!!!
Ryan0348
« Reply #7 on: 11 Dec 2019, 06:39 pm »
Hello Norman. I’m new to the site also. I live in newton ia. I have a GR Research super mini setup with the side firing m165 woofer base. I’m putting together the H frame servo subs right now.
Wally_C
« Reply #8 on: 12 Dec 2019, 08:51 pm »
Welcome Norman!
