Riggle Engineering 12" String Theory Tone Arm AKA The Woody. SOLD
0 Members and 1 Guest are viewing this topic. Read 1718 times.
Mister Pig
  • "when pigs fly"
    • Affordable Audio/Positive Feedback Online writer
I have serial #11 arm from Pete. It has been installed on only two tables in its lifetime, and only had 3 cartridges mounted on it. I do have some extras such as the lighter counterweight and the heavier brass cartridge fitting if you want to run low compliance moving coils. Has always been set up with the aluminum fittings for medium compliance cartridges.
You know the story about this arm. Its a high performance piece that does not cost an arm and a leg new, and at this price you will get major bang for the buck.
This arm however is not for the newbie. It has a ton of adjustments and you can get a cartridge dialed in like few other arms can. I no longer have tables that can accept a 12" arm, and I bought a Sota as my long term table, and this will never fit it. So its time for it to go to someone else who will enjoy it.
MSRP $1900 and a very long wait time to get one built
Sell $950
Typical disclaimer. The cartridge pictured does not come with it. Nor does the turntable base, or the table either. And sorry for the sunlight highlighted photos, it makes the mat look terribly dusty doesn't it?
« Last Edit: 28 Nov 2019, 06:25 am by Mister Pig »
