Source for a basic 15VDC power supply with a 2.1 mm power jack?
0 Members and 1 Guest are viewing this topic. Read 1749 times.
kbuzz3
Hi not sure if this post works best here or the lab but would appreciate any help Finding a budget power supply for an older Model marchand 108 phono stage. The unit needs a 15VDC power supply and have a 2.1mm power jack.
phil marchand says the supply should also have at least a 2A rating. Can anyone recommend a basic unit so I can see if this pre amp is still working?
Would this do it?
https://www.amazon.com/Power-Supply-5-5MM-2-1MM-Cable/dp/B076892FPX
or maybe this? Although this one says up to 4 amps.
https://www.parts-express.com/15v-4...h-21-x-55mm-center-positive-(-)-plug--120-057
Thanks again.
poseidonsvoice
    • 2 channel/7 channel setup
I would get the 4A one since you have a bit of headroom and Marchand had recommended at least 2A.
Best,
Anand.
kbuzz3
thanks....im clueless about electrical
