Help - sw12-08 question
0 Members and 1 Guest are viewing this topic. Read 1904 times.
[email protected]
« on: 19 Nov 2019, 10:33 pm »
Hi all,
I am hoping someone can help me. I recently purchased a sw-12-08 woofer. I though i was getting the sw-12-08fr. They don't have the same specs. Am i correct to assume i cannot use it in a H frame with a 08Fr?
Could i use it in a sealed box as a single? Or do i absolutely try to find a second matching woofer?
HAL
Re: Help - sw12-08 question
« Reply #1 on: 20 Nov 2019, 01:58 am »
If this was a recent purchase from GR-Research, the SW-12-08FR is the only one on the website.
Danny Richie
« Reply #2 on: 20 Nov 2019, 02:49 am »
Check the label on the magnet to confirm which model it is.
The standard 08 version is for a sealed box, and two can be paralleled and used in a sealed box.
The FR model is for free air applications.
[email protected]
« Reply #3 on: 24 Nov 2019, 12:08 am »
It is not the FR. I was lucky and found one on ebay for very very cheap.
I will use it in a sealed box for home theater use. If I want to use a second sealed sub, could I use a sw-12-04?
In terms of power, is the HX300 recommended for this type of use?
Danny Richie
« Reply #4 on: 26 Nov 2019, 03:53 am »
Sure just add SW-12-04 woofer and another amp and it will sound just like it.
You can use either the HX300 or the A370 style amp with it.
