Damage from inadvertent bridging?
0 Members and 1 Guest are viewing this topic. Read 2521 times.
Mike-48
« on: 17 Nov 2019, 08:57 pm »
James--
On my 4B3, the toggle inadvertently got switched to bridged mode while my speakers were connected as a stereo pair. Because I had just updated the firmware on my (non-Bryston) preamp, I thought the problem was there, and it took quite a few tests and a lot of head-scratching to figure out had what happened to the sound.
Since the incident, things don't sound quite right, maybe a bit muffled. But at the same time, we are having a lot of pollution, and I'm having a hard time keeping my ears clear. Is is likely that damage was caused, either to amp or to speakers, from running the system with the mistaken switch position?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Damage from inadvertent bridging?
« Reply #1 on: 17 Nov 2019, 10:18 pm »
James--
Hi Mike
No issue at all with damage to the amplifier other than very bad sounds while the switch is in the wrong position !
james
Elizabeth
« Reply #2 on: 17 Nov 2019, 11:02 pm »
Mike in NC... you have my deepest admiration for actually FINDING OUT what was wrong. I bet you spent a very long time looking...!!!!!
I know when some little 'unknown' error causes the system to fail.. it can be a genuine PITA to find out what it was. Since the switch is pretty hidden, and small, and unobtrusive.....
Jeez I cannot imagine to time it took to find it.... You had to have gone down the check every switch wire and connection route.. probably more than once...  :thumb:
Mike-48
« Reply #3 on: 18 Nov 2019, 02:39 am »
Elizabeth, Thank you! You're right, the problem was not easy to find, and I made a lot of mistakes before finding it.
And Bryston . . . I suppose you changed from slide switches on older models to toggles for a good reason, but damn! those little toggle switches are easy to trip without realizing it.
Mike-48
« Reply #4 on: 18 Nov 2019, 02:40 am »
Thanks, James. Can I assume that no damaging signal was sent to the speakers, either? Certainly nothing seemed loud -- quite the opposite!
Mike
« Reply #5 on: 18 Nov 2019, 03:08 am »
Mike
Hi Mike
I would assume the speakers are fine.
james
Mike-48
« Reply #6 on: 18 Nov 2019, 03:54 am »
Thanks again, James.
gbaby
« Reply #7 on: 19 Nov 2019, 07:59 pm »
Mike, where are you in NC, the West, East coast, the Piedmont or Triad? I'm on the east coast. Killer looking system you have by the way.  8)
Mike-48
« Reply #8 on: 22 Nov 2019, 11:56 pm »
Thanks! We lived in Beaufort for 11 years and moved to Portland, Oregon, 10 years ago. A lot to love in both places, but i had a bigger audio room in NC.
gbaby
« Reply #9 on: 5 Dec 2019, 03:42 pm »
You should have stayed in Beaufort, but I guest the hurricanes ran you away.  :lol: I live in New Bern. Wow, so close.
Mike-48
« Reply #10 on: 25 Dec 2019, 08:27 am »
@gbaby : A good friend grew up in New Bern. He was at the next table in a Portland restaurant, and after he spoke a few words, my wife leaned over and said, "You're from eastern North Carolina," and the friendship began.
Yes, hurricanes were a big factor in moving. We had been through many, and they create so much work! In Portland we might have floods, volcanoes, and earthquakes -- but in 10 years, none have hit. Maybe tomorrow....
Portland also offers better access to audio dealers. I made quite a few trips to the Raleigh area to pick out my previous speakers. I'd reserve a motel room, drive up on Saturday morning, visit dealers on Saturday and Sunday, and head home Sunday mid-afternoon.
« Last Edit: 26 Dec 2019, 02:40 am by Mike in NC »
