0 Members and 1 Guest are viewing this topic. Read 5364 times.
Hey John !! The first payment made it. Still waiting for number 2 But i think this week ill be ready for the RM30 . Say what does your system do with the subs ? Does it calibrate it ?
The R-DES system is a Digital Equalization System that allows you to measure your room...
Quote from: John CaslerThe R-DES system is a Digital Equalization System that allows you to measure your room...It has built-in measurement capability? Does it also include a calibrated mic? This would be a compelling reason to choose it instead of a full-function Behringer digital EQ.
I believe that you have to measure your own room using some other software, then enter the data. I don't think they could offer the product for $400 and include the measurement software (ETF is $150 I think, and a calibrated mic is $250).
Well, I've reached the conclusion that I can't use the R-DES in my situation. I want to use both subs and the main speakers to produce bass. I currently have an NHT X2 active crossover that runs the subs at about 50Hz and lower, but I'm also running the main speakers (RM40s) full range. If I use the R-DES on the subs only, I could get rid of one (massive!) peak below 50Hz. However, all my other peaks are above 50 Hz. What this means is that I'd have to apply the R-DES to less than 200 Hz (for instanc ...
John,As it currently stands, I have a massive peak around 28 Hz (approximately the calculated peak for my room dimensions). This is the only peak in subwoofer range. There are 3-4 more large peaks between about 50 to 200 Hz, where the ETF program stops recording data. I can be more specific if you'd like.
