WTB: MG Audio Design IC's
0 Members and 1 Guest are viewing this topic. Read 422 times.
highstream
« on: 2 Nov 2019, 09:46 pm »
In case anyone has spares...Due to system additions and different placement of component outputs, I could use a couple of additional reasonably priced 1 or 2m pairs of AG2 RCA or XLR interconnects, and maybe one CU2 (Series 2 with RF inductor sleeve preferred if XLR). Email me if you can help. Thanks,
« Last Edit: 13 Nov 2019, 05:19 am by highstream »
HanaEyes
Re: WTB: MG Audio Design IC's
« Reply #1 on: 12 Nov 2019, 08:06 am »
Is the S2 the newer version?
highstream
« Reply #2 on: 12 Nov 2019, 02:11 pm »
S2 added a ferrite core inductor, a little sleeve, on one end as an RF filter, on the balanced ICs. The found it didn’t make a difference with the single ended ones (RCA). I should clarify that in my post.
KLH007
« Reply #3 on: 23 Nov 2019, 01:53 am »
highstream, I have 1M pairs of AG1 and Cu2, RCA.
highstream
« Reply #4 on: 23 Nov 2019, 02:01 am »
Thanks for the reply. Everything is on momentary hold until the output wiring of my Lampi dac is corrected, which I hope will be in the next week. I’ll get back to you if I need the CU2. Thanks,
Gene
