Bryston bp4
0 Members and 1 Guest are viewing this topic. Read 1162 times.
almo
Bryston bp4
« on: 2 Nov 2019, 02:46 am »
Hello, l hope someone here can advise me on my preamp, or point me in the right direction.
 I recently pulled it from storage and replaced a beat up rotel unit. I immediately noticed the bp4 was much improved  in the bass and midrange but was slightly lacking in high end detail and ‘airiness’. As far as I know the bp4 may be in need of restoration, or could the two just be sonically different? If the bp4 needs a refresh, is it as easy as changing some caps myself or does it need to go to Bryston? Also, if I were to recap where can I get recommendations for brands and values.
Thank you in advance for any help.
« Last Edit: 12 Nov 2019, 03:13 pm by almo »
almo
Re: Bryson bp4
« Reply #1 on: 5 Nov 2019, 05:07 pm »
Hello again, obviously I came to the wrong forum. Could someone please tell me where to go for help?
 I took my bp4 out of the system and used the variable outputs of my cd player direct to amp. I find that the bp4 definitely has a veil over the highs. After inspecting and cleaning switches, I found no bulging caps. I cannot find how to get deoxit into the volume pot.
 At this point, I am considering replacing with a rotel or parasound pre as the Bryston is definitely veiling the upper frequencies. I have been a fan of Bryston for many years and have other Bryston gear but this latest comparison with Rotel surprised me to say the least. I'm saddened that a cheaper overseas built product outperforms the Bryston. That is why I turned to this site. My apologies to all for wasting your time.
Almo
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryson bp4
« Reply #2 on: 5 Nov 2019, 05:13 pm »
Hi - sorry just noticed this.
Can you send your comments to Mike at Bryston please in service.  The BP4 is an extremely old unit so may need some work.
[email protected]
james
almo
Re: Bryson bp4
« Reply #3 on: 5 Nov 2019, 05:53 pm »
Thank you James. My last experience with Bryston service was absolutely exceptional. I have a feeling it may not be worth restoring,  will  soon find out. Thank you again.
