HELP Identify these Speaker Cabinets - Fostex FE206e
0 Members and 1 Guest are viewing this topic. Read 1964 times.
intelonetwo
I came into these cabinets, drivers and subwoofer by way of a trade for some computer parts. Problem is I can't seem to find any info on the cabinet design to finish the build or even determine their worth.
Is anyone here familiar with this cabinet design? Also there is a seemingly matching subwoofer, though I have no idea what driver is in there.
I'm told it was built by a local carpenter but I have no way of contacting him.
Thanks in advance guys. I appreciate it.
hionhifi
intelonetwo
Re: HELP Identify these Speaker Cabinets - Fostex FE206e
« Reply #2 on: 28 Oct 2019, 11:50 pm »
Thanks for that.
My cabinet is 12 1/2” Wide x 42 1/2” Height x 13” Deep
On the Decware site they are 17” deep. Maybe mine is an older model.
Minor does look like the so-called “death box”.
opnly bafld
« Reply #3 on: 29 Oct 2019, 12:08 am »
Looking at the Decware picture, depth must include the base.
intelonetwo
« Reply #4 on: 29 Oct 2019, 01:48 am »
You got it!
I remeasured this time at the base and lo and behold it is 17“ there and 12 3/4” at the top.
So it’s a Decware NFX Full Range Single Driver Loudspeaker Design.
Thank you for the help.  :green:
My next question is do I use uncoated or coated 7“ foam balls to go inside the cabinets? The coded ones are like Nerf basketballs. The uncoated ones are like rough spherical foam sponges.
