Hi Glen,
Sure!
There are three additional boards and a pre-assembled power supply over the
analog pcb.
1. The Digital Control pcb (DCpcb) – 3 15/32” (88mm) long and 2 1/4” (57mm)
deep. This is the main pcb, incorporating the Atmel microprocessor, 4MHz
Crystal and Darlington switching array. It is fitted on stand-offs to the
base of the enclosure and is attached to both the Relay pcb and the Keypad
pcb with ribbon cable, and to the 5V 1A digital power supply via twisted
pair CAT5 cable.
2. The Relay pcb (RLpcb) – 3 1/8” (232mm) long by 2 5/8” (67mm) deep. This
pcb is fitted to the rear panel of the enclosure via the RCA blocks, and is
attached to the GK-1 analogue pcb with twisted pair CAT5E signal wires (and
the DCpcb with ribbon cable). The RLpcb incorporates all source selector
relays, all the input and output stereo RCA sockets, a Home Theater bypass
relay and a Mute relay.
3. The Keypad pcb (KPpcb) - Just over 5” (127mm) long by 2 3/8” (61mm)
deep. The KPpcb is fitted to the front panel of the enclosure for push
button control of source selection, mute and HT bypass. The IR Remote
Sensor unit is mounted on this pcb, which is attached to the RLpcb and DCpcb
with ribbon cable. The KPpcb incorporates six push button membrane switches
(seven with the phonograph option) and all indicator LEDs.
4. The Power Supply module (PSM) – 83mm x 108mm. Fitted to the base of the
enclosure, this is a fully built and tested module configurable for 110-120V
and 220-240V operation. It generates the 5V 1A supply for all digital
control circuitry. This is a linear supply with full regulation and short
circuit protection designed and built to hospital, high-reliability
standards. It is separated from the audio supplies so as to prevent the
intrusion of sharp digital control pulses into the audio chain.
Here's a picture. I find it tricky putting in an image, but here goes:
Hugh
