Panasonic, JVC, sharp digital amps bridged?
0 Members and 1 Guest are viewing this topic. Read 915 times.
CSMR
« on: 7 Feb 2005, 09:16 am »
I need to find one of these amps which is not bridged. I want one for use with a headphone adapter which takes joins the negative speaker terminals in a common ground. So I need to find an amplifier with a common ground (=not bridged, I think). I wrote to panasonic but haven't got a reply from their technical division. Does anyone here know?
Wayne1
« Reply #1 on: 7 Feb 2005, 02:17 pm »
The majority of the receivers you mention do not use common grounds.
There are many very good tube and op-amp based headphone amps out there. You may be better off if you limited your search to those, rather than the digital amps.
CSMR
« Reply #2 on: 7 Feb 2005, 11:20 pm »
Thanks Wayne1
