Yikes...confused on FryKleaner use...
0 Members and 1 Guest are viewing this topic. Read 1287 times.
Steveparry
« on: 7 Feb 2005, 07:53 am »
Hi,
I am using a FryKleaner (original) to burn in directional speaker cables using adapters from the center conductors of J2-5 to alligator clips.  The speaker cables are connected together so only four "ends" are an issue.  Should I connect J2(center) with the amp end of red to J5(center) to speaker end of red, and J3(center) SPEAKER END black to J4 AMP END black?
The alternative would to be to connect the amp ends to J2 and J3 and the speaker ends to J4 and J5, but with directional cable this doesn't seem correct...
Thanks!  Steve
hagtech
    • http://www.hagtech.com
« Reply #1 on: 8 Feb 2005, 03:27 am »
I'm not sure what the best way is to handle directional cables.  Haven't figured out what makes cables directional - so I'm at a loss.
jh :)
