Marantz PM 8005 Fantastic integrated amplifier in box
0 Members and 1 Guest are viewing this topic. Read 1508 times.
boniccie
Selling this amazing Marantz PM 8005 to move to the pearl series. This is a fantastic amp that drove my Magnepan 1.7 with ease due to the amazing output power supply. I used this amp just for couple hours on the weekends and it is absolutely in fantastic condition. The amp will come in all original box, manual,powercord, remote as showing in the picture. There is many reviews on the web, just google it and you will be surprised with the number of reviews..
Asking $595 now asking $545. Will ship Fedex Flat $55 within CONUS. Pickup is also welcome.
From Marantz website:
Combining fully discrete current feedback circuitry and our exclusive HDAM technology, the Marantz PM8005 integrated stereo amplifier delivers audiophile grade sound quality along with system operational flexibility. Rated at 70 watts per channel into 8 ohms, the PM8005 features a robust power supply along with high current capability to deliver 100 watts per channel into 4 ohms, for compatibility and operational stability with the widest range of loudspeakers.
Specifications
THD 0.02% (20Hz – 20kHz, 2 channel driven, 8 ohms load)
Input Sensitivity/Impeance PHONO:MM:2mV/47k ohms, LINE:200mV/20k ohms
Frequency response 5Hz – 100kHz ±3dB (CD, 1W, 8 ohms load)
S/N Ratio PHONO:MM:87dB, LINE:106dB, DIRECT IN: 125dB
Number of Channels 2
Output Power 70W (8 ohms), 100W (4 ohms)
Marantz HDAM Technology
The PM8005 features our exclusive HDAM (Hyper Dynamic Amplifier Module) technology, which consists of precision discrete selected circuit elements on a compact sub-board, instead of conventional op-amp integrated circuits. Multiple HDAM units are employed, including HDAM-SA3 and HDAM-SA2 versions that provide gain and buffering functions, to deliver dynamic and detailed sound quality. The PM8005 features current feedback technology for ultra low distortion and wideband response, along with superb musicality.
High Current Power Supply
The robust power supply features a high current toroidal main power transformer that is rated at 625VA, to easily provide extra power to the amplifier stage in order to handle demanding short term peaks. High current Shottky barrier diodes in the rectification stage are rated at 20 amps, with the ability to handle up to 180 amps peak current, providing sufficient power reserve to handle virtually any loudspeaker load.
ully Discrete High Current Output Stages
The PM8005 is equipped with multiple high speed, high current power output devices that are each rated at 14 amps of current output capability, providing a very high amount of dynamic headroom, along with compatibility with lower impedance loudspeakers. For optimum heat dissipation, the PM8005 is equipped with solid aluminum power amplifier heat sinks, with a combined total radiating area of 326 square inches, eliminating the need for fans. The PM8005 is conservatively rated at 70 watts per channel into 8 ohms, and 100 watts per channel into 4 ohms, for compatibility with the widest range of loudspeakers.
« Last Edit: 31 Oct 2019, 03:37 am by boniccie »
boniccie
Re: Marantz PM 8005 Fantastic integrated amplifier in box
« Reply #1 on: 26 Oct 2019, 02:28 pm »
Accepting reasonable offers.
