Calling Atma-Sphere Owners
0 Members and 1 Guest are viewing this topic. Read 1076 times.
Pstores
« on: 27 Sep 2019, 12:53 am »
As some of you know I have had a few pieces of equipment updated by the Atma-Sphere Crew. I picked them up on the used market. Otherwise, I’d never be able to afford such quality gear.  First would like to say I have never seen a company in which it’s employees take so much pride in their work.  Hats off to Ralph and everyone at Atma-Sphere. Best CS I’ve ever had with any company. And I do mean ever...
   Secondly I have had a pair of M60’s 3.0, and a pair of MA-1’s 3.1 updated to 3.3 versions. Also had Adam Hot Rod my UV-1 to the Hottest UV-1 ever built. A couple friends had MP-3’s updated to 3.3 status also. In each case of the Amps and MP-3’s they came back like a completely different piece of gear.  The updates  are such a difference it’s hard to believe it’s the same piece I dropped off.  The UV-1 was a big difference but not as dramatic. But it is a very simple bare bones circuit.  I would strongly suggest if anyone hasn’t updated to the current model 3.3 you really should. You will not be disappointed in anyway. Especially on the Amps, incredible. Also Ralph gives you a brand new 3 year warranty when you update. Pretty hard to beat that. It’s like having a new system.
  Simply put the 3.3 update is incredible. Everything sonically is improved. Which makes for a dramatic presentation upgrade. Ralph took great pieces of gear and made them incredibly better. His 3.3 update was the biggest advancement I think he’s had in my opinion.  My MA-1’s will be my forever amps. Now I dream of owning an MP-3
blazingsaddlez
Re: Calling Atma-Sphere Owners
« Reply #1 on: 2 Jan 2020, 04:06 pm »
Atma-Sphere is a fantastic company and they do have fantastic gear! I have their MP-3 MK3.3 preamp which I bought used. It has the cap upgrade, dampening package, and the side panel/top cover mod.
Truly a fantastic preamp. They say the MP-1 is a step above but to be honest with you, I'm not wild about the shear numbers of tubes you have to deal with.
In my system rolling tubes is wonderful because the sound of different tubes is VERY obvious. You can really customize your sound by tube rolling
Good luck!
