0 Members and 1 Guest are viewing this topic. Read 4609 times.
There isn't any sub-low freq. on a record anyway.
The cheapest thing to do is turn off the sub. There isn't any sub-low freq. on a record anyway.
This may seem obvious, but... why not just turn off the sub if it's only an occasional thing?
That’s not true.
Hi Saturn, Before cd's came out I had a Dahlquist subwoofer. As well as an Ace crossover I also used an Ace subsonic filter. It needed an outlet. I'll see what I can find, maybe Ebay....Mark.
In that case, I think you've found your best, cheap solution. It should remove some, maybe all of your rumble. Likely other remedies could be pursued as well. I'd bet you could find ways to dampen your partner's turntable or tonearm. Plasti-clay is cheap and effective.
Search "plasticlay" here. You'll find dozens of threads about using it to dampen turntables and tonearms. Many, including myself, have used it to good effect. Usually you can find it cheaper at Walmart --- https://www.amazon.com/Plast-i-Clay-Modeling-Color-Block-1838050MA/dp/B015TB4NYI/ref=sr_1_1?keywords=plasticlay&qid=1569454921&sr=8-1
I bought these for my sons system and they work great. Haven't noticed any degradation in sound and no hums. They go inline with the RCA's. They cut off 25hz and below. He was getting woofer chuffing and these worked like a charm.https://store.acousticsounds.com/d/60042/DB_Systems-DB_Systems_Subsonic_Filter-Turntable_Accessories
If you are getting a rumble (where the woofer is pushing in and out when there is no bass on the track or when there is otherwise quiet) then you might have a compliance mismatch between your cartridge and your arm. Happened to me. Instead of a rumble filter you should look into getting a cartridge that works properly with your arm.
Yes, I've seen this for many years during "silent" portions whenever an lp is playing. In fact, it will show as well with a blank disk. It, of course, is occurring when music is playing as well. Lots of amplifier power is being wasted on this non-musical information. Since it can be visibly "cured" with a subsonic filter, the question becomes does such a filter cause audible problems at higher frequencies? If one has a switchable subsonic filter, extensive a/b-ing may provide an answer for a given system.
