DSP crossovers and Phono Stages.
0 Members and 1 Guest are viewing this topic. Read 1721 times.
FreedomJazzDance
« on: 22 Sep 2019, 11:15 am »
DSP crossovers and Phono Stages, share your thoughts....
It's a big compromise to the phono signal?
TomS
FreedomJazzDance
Re: DSP crossovers and Phono Stages.
« Reply #2 on: 22 Sep 2019, 01:19 pm »
Thanks, appears that did not make any difference when listening, even with the errors that appeared on the measurements..
I hope that will appear more users of DSP with phono stage here on my topic, and share their experiences..
andyr
« Reply #3 on: 9 Dec 2019, 05:59 am »
Yes, classic question!   :lol:
A few years ago, after moving into a new house ... I had to move away from active speakers which had a 3-way analogue XO to a 4-way miniDSP setup (as I added a pair of subs and had to delay my main speakers to time-align with my subs).
Before the change, I had no digital:
* phono stage fed the preamp (together with other inputs)
* preamp fed the 3-way, analogue active XO
* active XO fed 6x Class AB monoblocs.
After the change it was:
* preamp fed the analogue inputs of the miniDSP
* analogue outputs of the miniDSP fed 8x monoblocs.
I then changed the way I was using my miniDSP unit - by feeding my phono stage into an A2D converter and thence into the digital input of the miniDSP.  IOW, I was digital as much as it was possible.
There were certainly no negatives in this change - only positives!   :)
Andy
