Carver ZR1000 help needed
0 Members and 1 Guest are viewing this topic. Read 2069 times.
celo
« on: 20 Sep 2019, 10:57 pm »
Hello,
Does anybody know if the transformer can be rewired for 230V operation?
What model Tripath module/chip was used in this amp?
Thank you!
Re: Carver ZR1000 help needed
« Reply #1 on: 20 Sep 2019, 11:23 pm »
If the transformer are non encapsulated it can be rewired by a experienced tech using the same core.
celo
« Reply #2 on: 20 Sep 2019, 11:43 pm »
Please correct me if I am wrong but this transformer can be rewired for 234V operation.
Actually I think it even says if I plug it to P104 socket, it will act
like 234V, correct? I just need to replace the fuse with 6A.
And it is TA0104A module.
I found this right after I opened this subject here.
ftp://187.104.182.100:2100/infotecnicabrasil/CARVER/audio/Carver%20Amplificador%20ZRSeries.pdf
« Reply #3 on: 21 Sep 2019, 12:32 am »
Yes you can rewind a primary to 230V used in Euro zone if the core is uncapsulated or even the secondary, I have not located the detail you mentioned sorry, it a big PDF.
OBS.: Ok just found it with another browser, This schematic transformer show two primary 117V each to be used with bi-phase 117V + 117V mains outputing 234V at secondary.
It dont grant your amp was assembled this way it must be checked in loco and tested. You must have 4 wires at the input transformer Brown, White, Black, Blue.
