7 Plus bend radius
0 Members and 1 Guest are viewing this topic. Read 5325 times.
abuhannibal
7 Plus bend radius
« on: 20 Sep 2019, 11:59 am »
Hi folks. Considering a 7 Plus for use with my Ayre power amp. But space is tight behind the rack and the cable would need to be bent with about a 4-inch radius behind the IEC plug.  Workable?
(To clarify: I mean a 4-inch radius not including the IECplug itself - I've got 4 inches from the back of the plug (roughly) to the wall.
Also: A right angle IEC might help but Ayre puts its Ayrelink connectors (RJ-45 jacks) directly underneath the IEC inlet. Would probably be OK anyway but I am not 100% sure.
Thanks in advance!
jriggy
Re: 7 Plus bend radius
« Reply #1 on: 20 Sep 2019, 03:32 pm »
You mean from the back of the plug attached to the cord itself right?  If so, you should be good. I just measured one of mine and the natural arch/hang down is 4 & 1/2 inches out, with an easy ‘push down’ to 4” or even a little less, if needed. Pete’s cables are pretty flexible.
abuhannibal
« Reply #2 on: 20 Sep 2019, 03:42 pm »
Correct. Thanks!!
Triode Pete
« Reply #3 on: 20 Sep 2019, 08:27 pm »
Hello abuhannibal,
If needed you could wrap a "Seven Plus" power cord around a clinched fist... a 4 inch bend radius should not be an issue, due to the multiple, soft highly annealed conductors in a "Seven Plus" power cord...
Also, I do offer a right angle connector for either the mains or IEC ends...
Pete
mresseguie
« Reply #4 on: 20 Sep 2019, 08:52 pm »
Hello abuhannibal,
Pete
Pete,
Is the right angle down only, or can it be to the left or right of the receptacle/wall?
Michael
Triode Pete
« Reply #5 on: 20 Sep 2019, 09:51 pm »
Pete,
Michael
Hi Michael,
There are multiple sets of female threaded inserts on the right angle connector body so that several orientations (up / down / left / right) can be achieved, as desired.
Pete
mresseguie
« Reply #6 on: 20 Sep 2019, 10:13 pm »
That's great!
I need to send one of my 7s back to you for re-orientation. It's straight now, but needs to go left.  :green:
abuhannibal
« Reply #7 on: 22 Sep 2019, 08:11 am »
Pete, thanks. So it sounds like the regular version will be fine for me but I'll mull it over. Last question: Is it possible to pick up orders in person?
Triode Pete
« Reply #8 on: 22 Sep 2019, 10:34 pm »
Yes, if you're in the NYC / LI area...
Pete
