SOLD : NSMT Model 50 / Jamaica - $1199
0 Members and 1 Guest are viewing this topic. Read 963 times.
milindks
« on: 13 Sep 2019, 10:14 pm »
These are pretty new speakers bought in May 2019, I am the 2nd owner of these beautiful speakers, and I am selling these as i need bigger speakers (Have a big listening room open to kitchen). There are some spots (shown in photo) on the top of one of the speakers (due to cup of tea) which is difficult to spot.
New speakers were originally priced at $1995 but now there is price increase and they are listed for $2499 on the NSMT website
The warranty card is still not filled and sent so you can fill and send it to NSMT.
Shipping Weight: 60 pounds each (shipping will be from 55344, MN)
I have had so many many speakers in my system to name few B&W, Paradigm, Maggies, Odyssey, Usher and these NSMT speakers are the speakers those have soundstage that is better than any other speakers i have heard in my systems, these speakers disappear with the music with lot of depth you can feel the space between instruments and performers. very efficient speakers 101 DB work well with small tube, SET amps (2/3 watts) very well as well as work well with high power solid state amps.
As this is front ported design speakers can be set very close to the wall.
There is review done by Terry London on home theater review as well as there is some discussion around these on audiogon speaker forum over here.
The Model 50 speaker's performance shines in the areas of tonality, details are easily heard because of its transparency, it's a very dynamic design that gives life to the music, it produces a reference level of sound-staging/imaging, and because of its double transmission line loading you won't have to get a subwoofer for music or movies.
Specs -
SPECIAL FEATURES:
Drivers: Custom hi-power, high sensitivity 8 inch paper cone woofers with phase plug and modified 1 inch soft dome tweeter arranged in quasi point source time coherent MTM arrangement
Drivers are all wired in positive polarity to preserve the waveform of original recording.
Time Coherence: Time coherent, minimum phase design
Crossover: Crossover-less broad band woofers, second-order crossover to tweeter.
Connectors: five-way insulated gold plated binding posts.
Single wire
Wiring: MasterSource multi-strand copper wire to tweeter and woofers.
Cabinet: Made from certified “green” real red birch wood laminated CARB 2 “formaldehyde-free,” anti-resonant medium density board. Only non-toxic paints and glues are used.
Support: Custom CNC machined aluminum outriggers with spikes
Warranty: Limited 5-year warranty.
TECHNICAL DATA:
Dimensions: 42 X 9.5 X 9 (H X W X D) with grill (Grills are available for extra $150)
Frequency Response: 38Hz – 18.5kHz +/- 3.5 dB
Bandwidth: (-10 dB): 28 Hz - 20 kHz
Sensitivity: 101 dB 1 watt/meter
Rated Impedance: 8 ohms
Minimum DCR: 7.7 ohms
Recommended Power: 1-500 watts
Reviews - https://hometheaterreview.com/nsmt-loudspeakers-model-50jamaica-speaker-reviewed/
Thanks for looking
« Last Edit: 22 Sep 2019, 03:09 am by milindks »
milindks
SOLD : NSMT Model 50 / Jamaica - $1099
« Reply #1 on: 19 Sep 2019, 12:21 am »
Price reduced $1299 to $1099
« Last Edit: 22 Sep 2019, 03:08 am by milindks »
