New Use for SilClear
0 Members and 1 Guest are viewing this topic. Read 965 times.
John Casler
« on: 5 Feb 2005, 01:04 am »
While it won't "improve" the sound of your system it can improve the performance.
How many times have you "hit" the remote control on the couch or you hand just to "jar" the batteries a bit so they make better contact?
Well since they send you so much extra SilClear, you migh as well place a little on the remote contacts and that will help the problem a bit, or at least it did on mine.
TheChairGuy
« Reply #1 on: 5 Feb 2005, 05:32 pm »
Another good one, John.
I use the Mapleshade product on the batteries of a few flashlights in the house, too, they seem to be a little brighter (and I hope last longer with the silver connection) in strength after applying.  The Caig R5 had teh same effect, too, when I Caig'ed them a couple years back.
Don't want those flashlights going dead when you need them most.  Here in quakey (flaky?) San Fran we think of worst case scenarios a lot  :wink:
