Default Would like to know more analog crossovers similar to Fostex EN3000 and E
0 Members and 1 Guest are viewing this topic. Read 1019 times.
FreedomJazzDance
I would like to know more analog crossovers similar to this models from Fostex, EN3000 and EN3020, EN3000 appears regularly to sell in Japan, the more sophisticated one EN3020 it's much more hard to find...
Anyway, would like to know more units with similar characteristics like this ones, very straight forward 3 way, easy to use.
For those who not know this Fostex, here they are:
EN3000: https://www.hifido.co.jp/sold/14-84210-27250-00.html
EN3020: https://www.hifido.co.jp/sold/11-62786-28291-00.html?LNG=E
Thanks.
No DSP's recommendation please.
gab
https://www.marchandelec.com/electronic-crossovers.html
don't know anything about EN3000 and EN3020 so I have no idea of how "similar" they may or may not be
FreedomJazzDance
Fostex EN-3000
https://audio-heritage.jp/FOSTEX/etc/en3000.html
Pictures: https://www.hifido.co.jp/sold/17-11127-51780-00.html?LNG=E
Specs:
Model Channel divider
Specifications 2-3way electronic dividing network
Bandpass characteristic 18dB / oct
Input impedance 47kΩ
Input sensitivity 0.5V (rated output)
Rated output 1V (Low: 100Hz, Mid: 1kHz, High: 10kHz)
Maximum output 8V (+ 18dB / dBV, distortion 0.05% or less)
Output impedance 470Ω
Total harmonic distortion 0.005% or less (rated output)
Crossover frequency 2way-1: 500, 650, 800, 1.2kHz
2way-2: 2k, 3k, 5k, 8kHz
3way: 500, 650, 800, 1.2kHz (Low / Mid)
2k, 3k, 5k, 8kHz (Mid / High)
Output phase switching 0 °, 180 ° (Low, Mid, High)
S / N 100dB or more (IHF-A)
Input / output terminal RCA pin terminal (pure gold plating)
Power supply AC100V
Power consumption 4.3W
Dimensions Width 482x Height 44x Depth 235mm (19 "/ 1U Standard Rack Mount Size)
Weight 3.5kg
Fostex EN-3020
Pictures and specs:
http://www.audiocostruzioni.com/r_s/accessori/fostex-an3020-crossower/fostex-en3020.htm
Manual available here:
https://www.fostexinternational.com/docs/tech_support/manuals.shtml
Thanks.
