FS: Cables and odds and ends
0 Members and 1 Guest are viewing this topic. Read 3097 times.
sac8d4
« on: 2 Sep 2019, 11:41 pm »
I have a few items for sale. Please see below:
Sound Anchor 24”  Single Post Stands Stand (Pair) The top plate measures 7” x 12”. The Speaker stands are equipped with M8 spikes. These are basically brand new, are very sturdy and have never been used in a setup. $200 not including shipping
Nanotec interconnects 302 Golden Strada #201 nano3 XLRs (1 Set) 1.8m $250 and RCAs (1 Set) 1m $250 *SOLD*
These are excellent sounding interconnects that compete with some very expensive cables on the market. These are an exceptional value. Unique design starting with an Oxygen-Free Copper conductor that is immersed in colloidal solution (squalene oil) with gold and silver particles. The isolator is made for PE, PVC, cotton strings, and Japanese Paper. Here is an excellent review of these interconnects https://www.6moons.com/audioreviews/nanotec4/interconnect.html
ZU Boks  power cable 2.0m (2) $75 each *SOLD*
Bok AC mains power cables are balanced high performance mains cable for home audio equipment. Bok is a very high conductance (#11 awg high/#11 awg low, #9 awg Earth) design. Bok features ZuB3™ E&M cable design. Here is an excellent review of the Boks http://www.6moons.com/audioreviews/zu13/cables.html
 Zu Ash Digital cable 1m (1)$75  *SOLD*
The Ash was Zu's top digital cable using their B3 geometry, silver alloy conductors and copper shielding. It features WBT-like locking RCA connectors. Excellent Condition
BDR Diamond Racing Racing cones MK4 ($65 for 4) and Discs ($75 for 4) (New, never used)
BDR Cones are created from a proprietary compound of Carbon Fiber and a proprietary aerospace Resin. They have a internal 1/4"-20 threading for your audio components. The Mk4 Cone is slightly cooler with greater top octave extension and less emphasis on the lower frequencies compared to the MK3.
*SOLD*
The Black Diamond Racing LM Disc improves bass weight and control, extends and smooths treble response, and greatly enhances midrange clarity and presence. Just slip a set under the stock feet of any piece of gear to hear an instant difference. Recommend use these under the BDR Cones for an incredible upgrade. The LM Discs can be used under speaker spikes or under any equipment rack. The LM Discs Measuring just 0.34” tall and 1.5" round.
EVS Ground Enhancers $15 *SOLD*
EVS Ground Enhancer contains a tuned configuration of OFC litz wire and the termination to your speakers, etc. is via an 18 awg PCOCC solid core copper wire. These little devices definitely improve the sound. I noticed more extended highs, lower distortion, cleaner transients, and an overall more musical quality of whatever recordings, I was listening to.
Belkin PURE|AV 24k Gold Speaker Spades
These are a heavy-duty spade with a solid construction that will fit around large speaker binding posts. They have a high copper content. I dissected one of them, they are a solid copper spade that threads onto the brass body w/ set screw that connects to the cable. I tossed the aluminum Belkin shell since I was going to simply putting heat shrink around the terminal.  30 spades for $40
Sound Mechanics C4 vibration controllers (10) *SOLD* – These are designed to be placed on top of equipment with the curved surface pointing down and in contact with the equipment. Experiment with the location of the C4 to achieve the best result. However, I used them as tuning devices around the room. $50 for the lot
Monacor MDM-3 Acoustic Damping Pads (4 packs) 75% Wool/25% Polyester mix *Sold*
Damping Pads for high-end speaker enclosures. Very high quality with excellent damping characteristics. Each pack contains 2 no pads 63 x 33cms, 35mm thick.  $30 for all 4
VIABLUE XS High-end RCA Subwoofer Y Adapter $10 *Sold*
Not a flimsy y adapter, specifically made for subwoofer with dual RCAs. 1x RCA female to 2x RCA male
Isotek Full System Enhancer & Rejuvenation Disc $25 *Sold*
This burn-in and enhancement disc greatly speeds up the break-in time of loudspeakers as well as demagnetizes, it also rejuvenates your audio system allowing it to function at its optimum level.
Here's a review of Isoteks’s Rejuvenation Disc http://6moons.com/audioreviews/isotek/cd.html
K2 HD Sound Various Artist 100 KHZ and 24 Bit Resolution $25 *Sold*
This is K2 HD Sound! Sampler disc is mastered with superior skill of mastering engineer and revolutionary "K2 High Definition Coding" technology. K2 HD Mastering enhances the sound spectrum to a bandwidth of 100kHz and 24-bit resolution, while retaining all the charm of the original recording. K2 HD mastered CDs offer extended nuances, dynamics and musicality and are playable on any CD player.
Zubin Mehta, Also Sprach Zarathustra – K2HD Mastering $25 *Sold*
Excellently recorded album. This album will put your system to task
Please send me a reply if you are interested in any of the items.
« Last Edit: 13 Aug 2021, 03:04 pm by sac8d4 »
mooncrikit
Re: FS: Cables and odds and ends
« Reply #1 on: 3 Sep 2019, 03:11 am »
PM sent, please check your inbox, jeff
mooncrikit
« Reply #2 on: 6 Sep 2019, 02:01 pm »
I paid you for the CD 'This is the K2 sound' please confirm receipt and when I can expect shipment. Thanx, Jeff
sac8d4
« Reply #3 on: 8 Sep 2019, 11:54 pm »
Received payment. I will ship it out on Monday.
mooncrikit
« Reply #4 on: 9 Sep 2019, 02:28 am »
That's great! Please forward the tracking info once it is generated, thanks, Jeff
rpw
« Reply #5 on: 9 Sep 2019, 04:45 pm »
PM sent
sac8d4
« Reply #6 on: 16 Sep 2019, 03:26 am »
Price reduction on the Zu Boks $100 each
sac8d4
« Reply #7 on: 27 Sep 2019, 03:37 pm »
Bump, If you purchase both the Nanotec ICs, I'll let them go for $450 for the pair.
sac8d4
« Reply #8 on: 24 Nov 2019, 06:25 pm »
Bump, many items are still available. Feel free to make offers on items you might be interested.
Jazzk
« Reply #9 on: 29 Dec 2019, 09:13 pm »
Interested I the zu digital and the vibration control.  Still available?
sac8d4
« Reply #10 on: 17 Apr 2021, 09:25 pm »
sac8d4
« Reply #11 on: 2 May 2021, 11:23 pm »
Up for grabs is a Lovan Sovereign Amp stand with Rosewood board. $75... Prefer local sale but will ship at buyers cost.
The board is in excellent shape with no major ding scratches. there are a few scratches but they are very minor micro scratches in surface in a few places. Stand posts are loaded with banite steel shot and sealed with black silicone caulk.
GIK Panels  242s (2) and 244 (1) in Coffee $100. I would prefer local pickup in Tucson, AZ as they cost $$$ to ship due to size.
No rips or tears in coffee fabric, however due to the way the panels are constructed with the fabric pulled taunt over vinyl corner beading, it looks like there is wear. The is the way they arrived from GIK.
willief23
« Reply #12 on: 11 Aug 2021, 12:52 pm »
pm sent, im interested in some discs.
