Sold in CT Hawthorne Audio Sliver Iris open baffle
0 Members and 1 Guest are viewing this topic. Read 793 times.
flavo
« on: 31 Aug 2019, 01:45 pm »
SOLD
https://www.usaudiomart.com/details/649546069-hawthorne-audio-sliver-iris/
$250
I have these Hawthorne Audio 15" silver iris FS along with the 15" Eminence sub woofers.
The Yung sd100 amp goes with this as well.
This is a great plug and play set up for super cheap.
The baffles are just test baffles. They will get you started, but the drivers really deserve much better. Not just for the looks, but for rigidity. The reinforced 1/2" plywood isn't nearly stiff enough to keep up with the Eminence subs on the bottom.
The baffles appear to be tilted at different degrees. That's just an illusion of the photo. They are both tilted the same degree.
« Last Edit: 23 Nov 2019, 02:41 am by flavo »
flavo
Re: FS in CT Hawthorne Audio Sliver Iris open baffle
« Reply #1 on: 24 Oct 2019, 10:19 pm »
bump
